G840H FAQs
Find your answer here
Basic Knowledge
G840H provides two resolution options:
2.5K(front) and 1080P(rear) or 1080P(front) and1080P(rear)
The reverse line of G840H can be adjusted by sliding the line on the screen according to the actual situation.
It supports two reversing modes: Full-screen display and Panorama display, both of which can be switched by clicking the icon in the lower right corner of the reversing image.
With the Full-screen display turned on, the reversing image will be automatically enlarged by 1.5 times.
With Panorama display turned on, the reversing image will not be enlarged and show the actual distance.
Please note: Under Panorama display, the reverse line cannot be adjusted and saved.
1. The front camera behind the mirror can get more angles by moving it slightly, and the rear camera by changing the installation position.
2. Swipe the the screen up and down to get more viewing angle.
3. The rear camera image can be mirrored or flipped
The brightness of the screen can be adjusted by clicking the "brightness icon" on the screen. The current version of the G840H does not support the zoom function.
The rear camera is waterproof, and you can get a clearer view in the rain by spraying water-repellent spray on the lens. It is recommended to protect the camera when washing the car, as high-pressure water vapor may seep into the inside of the camera.
The current version of the G840H is not equipped with LDWS and ADAS
The current version of G840H is equipped with WIFI and APP. The APP can be downloaded by scanning the QR code on the WOLFBOX official website, or searching for WOLFBOX in the app store Please note: WIFI needs to be turned on manually before connection.
Usually the rear camera is installed above the license plate to get the best viewing angle and image, it can also be installed inside the car. License plate brackets are currently available on our website.
The parking monitoring mode of G840H can provide protection for your vehicle after parking. Parking mode: With this option turned on, the dashcam will enter time-lapse recording mode after parking. its working time can be set as 12H/24H.
PLEASE NOTE: Correct installation of the hardwire kit is required for Parking Monitor Mode to work properly. The basic installation method is that the yellow wire of the hard wire kit is connected to B+ or a fuse with a constant power supply, the red wire is connected to the ACC fuse, and the black wire is grounded.
Normally, "Will enter time-lapse " will be displayed on the screen after the car is turned off. When you touch the button again, it will prompt "ACC is off, not operate" If Time-lapse is enabled, the video recorded in the parking monitoring mode can be found in the video file after the next boot.
Possible reasons:
1. The hard wire kit is connected incorrectly. Please contact support for wire connection issues or seek professional installation.
2. The car voltage is lower than 11.8V. The hardwire kit will automatically power off when the car voltage is lower than 11.8V to avoid draining the car battery.
3. The hardwire kit is defective.
4. The option of parking monitor is not turned on in menu/ on App.
In order to avoid new videos not being saved and frequent formatting of the TF card when the TF card is full, the dashcam turns on the loop-recording mode by default. In this mode, the recording time of each video can be manually set to 1 min, 2 min or 3 min, and when the TF card is full, the new video will automatically overwrite the old video to achieve loop recording.
2. Insert a new TF card.
1. The WIFI option needs to be turned on manually in the menu before connecting.
2. The connectable range of WIFI is about 5 meters.
3. WIFI cannot be used to connect to the Internet, it is only used for data transmission.
Possible reasons:
1. Please check if the AV input on the top of the mirror is broken.
1. If the mirror does not turn on after updating the firmware, it may be that the mirror has been installed with wrong firmware, please contact support to get the correct firmware.
2. Please confirm whether the power port on the top of the mirror is damaged or not.
3. Please unplug the GPS, TF card and the rear camera cable, and use a new charger with a compatible interface to power the mirror to see if it can be turned on.
Possible reasons: Warning sound of Fatigue reminder or Speeding reminder. After plugging in the GPS device, the dashcam will give out a warning sound when speeding.
Please make sure that the layer of film on the lens is torn off and wipe the lens with a cleaner. Get an upgraded WDR rear camera to reduce glare
1. Please try inserting a new TF card.
2. If the new TF card does not make it work, please contact support or get the firmware from WOLFBOX official website.
It is possible that the card speed of the inserted TF card is lower than the requirement. Please use Class 10 and U3 TF cards. TF cards compatible with the product can be purchased on the WOLFBOX website.
1. Please make sure that WIFI is turned on in the menu.
2. After turning on WIFI, please check whether WOLFBOX- G840H can be found on the WIFI list on the phone.
3. If the App displays "Connection Failed", please find Get Support in the App and contact us.
The WIFI password can be found in the WIFI Switch option in the menu. The default password is 12345678
More about G840H
| Display Screen Size | 12" |
| Video Resolution | 2.5K and 1080P |
| Aperture | 1.5F |
| Frame Rate | 2.5K25fps+1080p25fps |
| DDR | 2GB |
| FLASH | 128Mb |
| Weight/lb | 0.83 |
| Touch Screen | Support |
| Super Night Vision | Support |
| Wi-Fi | Support |
| App Connnected | Support |
| Loop Recording | Support |
| G-sensor | Support |
| Reversing Aid | Support |
| Parking Monitoring with hardwire kit | Support |
| Maximum Storage | 256G |
