G900 FAQs
Find your answer here
Basic Knowledge
The G900 provides two resolution options: 4K(front) and 2.5K(rear) or 2.5K(front) and 2.5K(rear)
The reverse line of G900 can be adjusted based on pre-set three options of H/M/L. It supports two reversing modes: Full-screen display and Panorama display, both of which can be switched in the menu or by clicking the icon in the lower right corner of the reversing image. With the Full-screen display turned on, the reversing image will be automatically enlarged by 1.5 times. With Panorama display turned on, the reversing image will not be enlarged and show the actual distance.
1. The front camera behind the mirror can get more angles by moving it slightly, and the rear camera by changing the installation position.
2. Swipe the left side of the screen up and down to get more viewing angle.
Screen brightness can be adjusted by swiping up and down the right side of the screen. The front image cannot be zoomed, but the rear image can be zoomed in or out by swiping the far right side of the screen.
IP68 waterproof. The rear camera is waterproof, and you can get a clearer view in the rain by spraying water-repellent spray on the lens. It is recommended to protect the camera when washing the car, as high-pressure water vapor may seep into the inside of the camera.
The current version of the G900 is not equipped with LDWS and ADAS
The parking monitoring mode of G900 can provide protection for your vehicle after parking.
There are two options in Parking Monitoring Mode.
1. Collision boot recording: With this option turned on, when the vehicle is hit after parking, the dash cam will detect the collision and automatically save the emergency video. And emergency recordings will be saved in a locked folder to prevent deletion.
2. Lapse-record: With this option turned on, the dashcam will enter time-lapse recording mode after parking. In this mode, the camera will save video at intervals of 1S/2S/3S and its working time can be set as 12H/24H/48H.
Please note: In G900, this option can only be enabled after the collision boot recording is disabled.
After installing the hardwire kit, there will be an option of "Parking Monitoring Mode" in the menu, and you need to enable Collision boot recording or Time-lapse.
PLEASE NOTE: Correct installation of the hardwire kit is required for Parking Monitor Mode to work properly. The basic installation method is that the yellow wire of the hard wire kit is connected to B+ or a fuse with a constant power supply, the red wire is connected to the ACC fuse, and the black wire is grounded.
Normally, "Entering Time lapse" or "Entering parking monitoring mode" will be displayed on the screen after the car is turned off. When you touch the screen again, it will prompt "ACC is off, not operate" or "Please exit the parking monitor" If Time-lapse is enabled, the video recorded in the parking monitoring mode can be found in the normal file after the next boot. If the Collision boot recording mode is turned on, you can try to shake the mirror after it enters the parking monitoring mode, and then turn it on to check whether there is an emergency recorded video in the locked folder.
In order to avoid new videos not being saved and frequent formatting of the TF card when the TF card is full, the dashcam turns on the loop-recording mode by default. In this mode, the recording time of each video can be manually set to 1 min, 3 min or 5 min, and when the TF card is full, the new video will automatically overwrite the old video to achieve loop recording.
2. Insert a new TF card.
Possible reasons:
1. Please check if the AV input on the top of the mirror is broken.
1. If the mirror does not turn on after updating the firmware, it may be that the mirror has been installed with wrong firmware, please contact support to get the correct firmware.
2. Please confirm whether the power port on the top of the mirror is damaged or not.
3. Please unplug the GPS, TF card and the rear camera cable, and use a new charger with a compatible interface to power the mirror to see if it can be turned on.
Possible reasons: Warning sound of Fatigue reminder or Speeding reminder. After plugging in the GPS device, the dashcam will give out a warning sound when speeding. Fatigue reminders can be turned off in the menu.
Please make sure that the layer of film on the lens is torn off and wipe the lens with a cleaner.
More about G900
| Display Screen Size | 12" |
| Video Resolution | 4K(front) and 2.5K(rear) |
| Aperture | 1.5F |
| Frame Rate | 4K25fps+2.5K25fps |
| DDR | 4GB |
| FLASH | 128Mb |
| Weight/lb | 0.83 |
| Touch Screen | Support |
| Super Night Vision | Support |
| G-sensor | Support |
| Loop Recording | Support |
| Reversing Aid | Support |
| Parking Monitoring with hardwire kit | Support |
| Maximum Storage | 256G |
