i05 FAQs
Find your answer here
Basic Knowledge
i05 provides three resolution options: Front cam: 2160P/1440P/1080P
The i05 is not equipped with reverse lines or parking assist
The camera can be rotated to get more viewing angles.
The current version of i05 is equipped with WIFI and APP. The APP can be downloaded by scanning the QR code on the WOLFBOX official website, or searching for WOLFBOX in the app store
Usually the rear camera is installed on the rear windshield.
i05 needs power supply and video signal transmission through cables.
The i05 is not rechargeable and needs to be powered via a cable.
i07 needs power supply and video signal transmission through cables.
1. Collision boot recording: With this option turned on, when the car is collided, the dash cam will detect the collision and automatically save the emergency recording video.
2. Time-lapse video duration: With this option turned on, the dash cam will enter the time-lapse recording after parking. Its working time can be set as 12H/24H/48H.
PLEASE NOTE: Correct installation of the hardwire kit is required for Parking Monitor Mode to work properly. The basic installation method is that the yellow wire of the hard wire kit is connected to B+ or a fuse with a constant power supply, the red wire is connected to the ACC fuse (12V-24V), and the black wire is grounded.
After turning off the car, the video transmission on the App will be disconnected, and the red light on the dashcam will continue to flash.
Possible reasons:
1. The hard wire kit is connected incorrectly. Please contact support for wire connection issues or seek professional installation.
2. The car voltage is lower than 11.8V. The hardwire kit will automatically power off when the car voltage is lower than 11.8V to avoid draining the car battery.
3. The hardwire kit is defective.
4. The option of parking monitor is not turned on on the App.
In order to avoid new videos not being saved and frequent formatting of the TF card when the TF card is full, the dashcam turns on the loop-recording mode by default. In this mode, the recording time of each video can be manually set to 1 min, 2 min or 3 min, and when the TF card is full, the new video will automatically overwrite the old video to achieve loop recording.
2. Insert a new TF card.
Possible reasons:
1. Please check if the AV input on the top of the main unit is broken.
1. If the main unit does not turn on after updating the firmware, it may be that the unit has been installed with wrong firmware, please contact support to get the correct firmware.
2. Please confirm whether the power port on the top of the unit is damaged or not.
3. Please unplug the GPS, TF card and the rear camera cable, and use a new charger with a compatible interface to power the main unit to see if it can be turned on.
Please make sure that the layer of film on the lens is torn off and wipe the lens with a cleaner. Get an upgraded WDR rear camera to reduce glare
1. Please try inserting a new TF card.
2. If the new TF card does not make it work, please contact support or get the firmware from WOLFBOX official website.
1. Please make sure that WIFI is turned on in the menu.
2. After turning on WIFI, please check whether WOLFBOX_ i05 can be found on the WIFI list on the phone.
3. If the App displays "Connection Failed", please find Get Support option in the App and contact us.
Please try to reset the unit or update the firmware, then the password will become the default:12345678
More about i05
| Display Screen Size | / |
| Video Resolution | 4K and 1080P |
| Aperture | F1.5 |
| Frame Rate | 4K30fps+1080p25fps |
| DDR | 2GB |
| FLASH | 128Mb |
| Weight/lb | 0.23 |
| Touch Screen | not Support |
| Wi-Fi Connection | Support |
| Super Night Vision | Support |
| G-sensor | Support |
| Loop Recording | Support |
| Maximum Storage | 256G |
