i07 FAQs
Find your answer here
Basic Knowledge
i07 provides four resolution options:
1080P(front), 1080P(inside) and 1080P(rear)
2.5K(front), 1080P(inside) and 1080P(rear)
4K(front)+1080P(inside)
The 4k(front) can only be available when the rear camera is not inserted.
The i07 is not equipped with reverse lines or parking assist
1. The cameras can be rotated slightly.
Available view angles:
150° front camera, 160° inside camera and 155° rear camera.
2. The rear camera image can be mirrored or flipped
The current version of i07 does not support zoom function and brightness adjustment. The exposure of the front camera can be adjusted in the menu.
The current version of the i07 is not equipped with LDWS and ADAS
The current version of i07 is equipped with WIFI and APP. The APP can be downloaded by scanning the QR code on the WOLFBOX official website, or searching for WOLFBOX in the app store Please note: WIFI needs to be turned on manually before each connection.
Usually the rear camera is installed on the rear windshield.
i07 needs power supply and video signal transmission through cables.
The i07 is not rechargeable and needs to be powered via a cable.
The bracket of the i07 is detachable, and the bracket can be removed by sliding the main unit.
The parking monitoring mode of the i07 can provide protection for the vehicle after parking.
Parking mode: With this option turned on, the dahcam will enter the parking monitoring mode after turning off the vehicle.
Monitoring sensitivity: Adjust the sensitivity of G-sensor.
Timelapse: The camera will save images at intervals of 0.5 sec/1 sec/5 seconds.
Time-lapse Recording Time: The working time can be set to 12H/24H/72H.
PLEASE NOTE: Correct installation of the hardwire kit is required for Parking Monitor Mode to work properly. The basic installation method is that the yellow wire of the hard wire kit is connected to B+ or a fuse with a constant power supply, the red wire is connected to the ACC fuse (12V-24V), and the black wire is grounded.
①Enable Timelapse and Time-lapse recording time in the Parking mode, and close Monitoring sensitivity. After turning off the car, "Enter time-lapse mode" will be displayed on the screen. In this combination, the video will be saved at intervals of 0.5 sec/1 sec/5 sec and can only be found in the Park file in Playback.
②Enable Monitoring sensitivity and Time-lapse recording time, but disable Timelapse. After turning off the car, "Enter Parking-monitor mode!" will be displayed on the screen. When a collision is detected, the screen lights up and displays a flashing yellow dot in the upper left corner, indicating that the dashcam has captured the collison. Videos will be saved in locked files instead of Park files.
③Enable Monitoring sensitivity, Time-lapse recording time and Timelapse at the same time. After turning off the car, "Enter time-lapse mode" will be displayed on the screen. Priority will be given to Timelapse recording.
The video will be saved at an interval of 0.5 sec/1 sec/5 sec and can be found in the Park file in playback.
Possible reasons:
1. The hard wire kit is connected incorrectly. Please contact support for wire connection issues or seek professional installation.
2. The car voltage is lower than 11.8V. The hardwire kit will automatically power off when the car voltage is lower than 11.8V to avoid draining the car battery.
3. The hardwire kit is defective.
4. The option of parking monitor is not turned in menu/ on App.
In order to avoid new videos not being saved and frequent formatting of the TF card when the TF card is full, the dashcam turns on the loop-recording mode by default. In this mode, the recording time of each video can be manually set to 1 min, 3 min or 5 min, and when the TF card is full, the new video will automatically overwrite the old video to achieve loop recording.
2. Insert a new TF card.
Possible reasons:
1. Please check if the AV input on the top of the main unit is broken.
1. If the main unit does not turn on after updating the firmware, it may be that the unit has been installed with wrong firmware, please contact support to get the correct firmware.
2. Please confirm whether the power port on the top of the unit is damaged or not.
3. Please unplug the GPS, TF card and the rear camera cable, and use a new charger with a compatible interface to power the main unit to see if it can be turned on.
1. Please try inserting a new TF card.
2. If the new TF card does not make it work, please contact support or get the firmware from WOLFBOX official website.
It is possible that the card speed of the inserted TF card is lower than the requirement. Please use Class 10 and U3 TF cards. TF cards compatible with the product can be purchased on the WOLFBOX website.
1. Please make sure that WIFI is turned on in the menu.
2. After turning on WIFI, please check whether WOLFBOX_ i07 can be found on the WIFI list on the phone.
3. If the App displays "Connection Failed", please find Get Support option in the App and contact us.
Please try to reset the unit or update the firmware, then the password will become the default:12345678
More about i07
| Display Screen Size | 3" |
| Video Resolution | 2.5K, 1080P, 1080P(R); 4K and 1080P |
| Aperture | inside the car:F1.8 outside the car:F1.55 |
| Frame Rate | 1440p30fps+
AHD1080p30fps+AHD1080p; 30fps 4K24fps+1080p24fps |
| DDR | 4GB |
| FLASH | 1Gb |
| Weight/lb | 0.31 |
| Touch Screen | not Support |
| Wi-Fi Connection | Support |
| Super Night Vision | Support |
| G-sensor | Support |
| Loop Recording | Support |
| Maximum Storage | 512G |
